Ipad2 unable to connect to wireless network (ipad3 are OK).
endpoint
Hi, we have setup a wireless network available for our customers with Web-Passthrough security. We have no issues with any customers' laptop and certain Blackberry devices but we do have issues with customers' ipad2 and some of newer Blackberry models (like Bold 9900). These units can see the wireless network, attempting to connect but with no success. Ipad3 have no issues. Majority of our customers are having ipad2 so wondering what could be done to solve this issue.
Appreciate your help and input.
16 Replies 16
Scott Fella
Can you post your show WLAN
I would like to see how your WLAN is configured.
-Scott
Here it goes:
(Cisco Controller) >show  wlan 10
WLAN Identifier.................................. 10
Profile Name..................................... Public WIFI
Network Name (SSID).............................. PublicWiFi
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Number of Active Clients......................... 46
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 28800 seconds
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ management
Multicast Interface.............................. Not Configured
--More-- or (q)uit
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Bronze (background)
Scan Defer Priority.............................. 5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Disabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
--More-- or (q)uit
   Accounting.................................... Global Servers
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Enabled
        ACL............................................. Unconfigured
        Email Input..................................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   H-REAP Local Switching........................ Enabled
   H-REAP Local Authentication................... Disabled
   H-REAP Learn IP Address....................... Enabled
   Client MFP.................................... Optional but inactive (WPA2 not configured)
   Tkip MIC Countermeasure Hold-down Timer....... 60
--More-- or (q)uit
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
(Cisco Controller) >?
So is the issue with local mode ap's or flexconnect or both? Are these ipads also connecting to other ssids or just this one?
-Scott
All APs are in H-reap mode; this wlan is for public use (available to our cusotmers) so "public" ipads are conencting only to this ssid.
Other SSID are not used for public. At this point we do not allow corporate ipads or BYOD in our environment.
Can you debug one of the clients? debug client mac adress
Im guessing the client is failing to associate correct or fail to get a dhcp?
-Scott
What wlc model, code and ap model?
-Scott
WLC = AIR-CT5508-K9
AP = AIR-LAP1142N-A-K9 (300+ APs)
AP = AIR-CAP3502I-A-K9 (3 APs)
Code = 7.0.116.0
I will try to get someone on site to troubleshoot client association tomorrow.
I have an ipad2 and ipad3 with no issues which is weird that you are having issues. Is it all ipad2 or just some?
-Scott
Okay.. one more question... are they getting the splash page?
-Scott
Sorry, I am not familiar with splash page - what is this?
Well your WLAN is setup for passthrough so the users must get a splash page in which they hit the accept or okay button.
-Scott
Well, majority of ipad2 are not able to conenct but i dont have enough details to assume that all ipad2 are not working. I will have users on site tomorrow with ipads to test.
I got some wireless clients that get IP Address from DHCP server:
10.65.56.101        01d8.b377.322f.38       Sep 20 2012 03:12 PM    Automatic
10.65.56.125        9cd2.4bf1.766b          Sep 20 2012 05:50 AM    Automatic
10.65.56.135        0180.6007.211a.06       Sep 20 2012 03:12 PM    Automatic
10.65.56.138        0158.946b.7065.28       Sep 20 2012 04:57 AM    Automatic
10.65.56.177        0164.a769.7623.57       Sep 20 2012 02:54 PM    Automatic
