Iphones and WLC - WPA
davidfield
Level 3
Level 3
Hello All,
Having a nightmare with iphones connecting to 2504 WLC.  I have WPA setup with PSK and laptops non apple connect ok.  My iphone is saying unable to join.  I roll back to No Security and iphone connects ok.
Seams to connect ok on native Vlan with WPA enabled but on tagged Vlans unable to join with Security.  Strange.
Running 6.1.2 on iphone
WLC
Software Version7.4.100.0
Field Recovery Image Version
Any ideas?  I've turned off Aironet on the interface with tagged vlan but no change.
Kindest Regards
David
This is an issue with many Apple devices...
Disable the session timeout
Wi-Fi Protected Access (WPA/WPA2)............. Enabled
WPA (SSN IE)............................... Enabled
TKIP Cipher............................. Disabled <<<<<<< This should be enabled with WPA1
AES Cipher.............................. Enabled  <<<<<<< This should not be used with WPA1
WPA2 (RSN IE).............................. Disabled
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
11 Replies 11
Scott Fella
Make sure your using WPA2/AES or WPA/TKIP and not both or a mix of both. If that doesn't help please post your show WLAN
-Scott
Thanks for responding Scott
Tried WEP and no joy either.    Just resetup WPA and not connecting see below settings
Dave
(Cisco Controller) >show wlan 3
WLAN Identifier.................................. 3
Profile Name..................................... Client
Network Name (SSID).............................. Home
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Client Profiling Status ....................... Disabled
   DHCP ......................................... Disabled
   HTTP ......................................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 0
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
User Idle Timeout................................ 300 seconds
--More-- or (q)uit
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... BKWWLC01
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ client
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
--More-- or (q)uit
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Disabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... 802.11b and 802.11g only
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
      Interim Update............................. Disabled
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
--More-- or (q)uit
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
      Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Disabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
--More-- or (q)uit
      CCKM TSF Tolerance......................... 1000
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional but inactive (WPA2 not configured)
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
AVC Visibilty.................................... Disabled
--More-- or (q)uit
AVC Profile Name................................. None
Flow Monitor Name................................ None
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
Also should mention no issues with other clients.  I've reset the WLC from scratch and still same issue.  Never had this problem before and Ive setup 4 in the last 2mths.
David
Scott
-Scott
Session timeout was the culprit by tthe looks of it.
Thanks Scott
Just makes sure you change your encryption also as it will help. I typically use WPA2/AES only and my iOS devices work fine.
-Scott
I spoke to soon.  I disconnected and forgot the network and reconnected and now gessatting same "unable to Join" messages.
I'm running out of ideas.  Anymore thoughts Scott?
So I have a bunch of iDevices at home and what I have to do to make sure they connect is to disable the session timeout, disable load balancing and use either WPA/TKIP or WPA2/AES. Can you post your show wlan again.
Scott
-Scott
Also reboot your iphone if you can.
Scott
-Scott
Where can i change this Session TimeOut Setting. Does it need to be done on the Cisco Wireless Controller ?
Hi David,
I just posted a new discussion: 2504 wlc, 3602 ap, 802.1 x authentication issues.
Scott replied to my discussion too.
I have the opposite results from you.
iPad, iPhone, and Android devices have successfully connected.
Windows 8.x clients do not connect.
My setup:
3 separate VLANs for mgmt, employees, guest.
using internal DHCP server on 2504 WLC.
I was assigned task for this implementation since the 4400 has a known Cisco bug due to Microsoft implementation on Windows 8.x
Now I wonder if the same bug is applicable to the 2504 WLC.
