ipsec and default route issue
syjeon
Level 5
Level 5
Hi.
I configured the ipsec on ASA and connected vpn through ipsec protocol.
I could connect to our local network but
I can't use internet, So I looked up my pc routing table, It is like below
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.4 1
0.0.0.0 0.0.0.0 192.168.100.1 192.168.100.201 1
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
169.254.0.0 255.255.0.0 192.168.0.4 192.168.0.4 30
169.254.0.0 255.255.0.0 192.168.100.1 192.168.100.201 20
192.168.0.0 255.255.255.0 192.168.0.4 192.168.0.4 20
192.168.0.0 255.255.255.0 192.168.100.1 192.168.100.201 20
192.168.0.1 255.255.255.255 192.168.0.4 192.168.0.4 1
192.168.0.4 255.255.255.255 127.0.0.1 127.0.0.1 20
192.168.0.255 255.255.255.255 192.168.0.4 192.168.0.4 20
192.168.100.0 255.255.255.0 192.168.100.201 192.168.100.201 20
192.168.100.201 255.255.255.255 127.0.0.1 127.0.0.1 20
192.168.100.255 255.255.255.255 192.168.100.201 192.168.100.201 20
211.189.156.85 255.255.255.255 192.168.0.1 192.168.0.4 1
224.0.0.0 240.0.0.0 192.168.0.4 192.168.0.4 20
224.0.0.0 240.0.0.0 192.168.100.201 192.168.100.201 20
255.255.255.255 255.255.255.255 192.168.0.4 3 1
255.255.255.255 255.255.255.255 192.168.0.4 4 1
255.255.255.255 255.255.255.255 192.168.0.4 192.168.0.4 1
255.255.255.255 255.255.255.255 192.168.100.201 192.168.100.201 1
Default Gateway: 192.168.100.1
Persistent Routes:
In normal situation, My default gateway is 192.168.0.1, But When I connected with vpn, the default changed 192.168.100.1, 192.168.100.1 is ASA's inside ip address.
Is it a normal operation?
rlacap
Community Member
syjeon
If your using an IPSEC vpn client make sure you have split tunneling configured or vpn on a stick configuration.
It would also help to see your firewall configs.
rlacap
