08-31-2020 02:38 PM - edited 07-05-2021 12:27 PM
Hey all,
I am currently testing iPSK for devices and so far it has worked fine until I tried to do an 8821 Cisco wireless phone. This connects, ISE shows it allowed, and it reconnects over and over and over. 700 times and counting. I've tested with a laptop, and even a roomba with no issues.
This is what sticks out for me, but not sure if it's the actual issue.
radiusTransportThread: Aug 31 21:16:23.066: c4:44:a0:3f:f6:3c Dot1x Authentication Error:Lrad Mac Address Received for client: c4:44:a0:3f:f6:3c is Zero
I've attached a client debug, but not sure if anyone else has tried iPSK and if they have run into issues.
WLC: 5520 running 8.8.130
ISE 2.6 Patch 7.
I don't think it's a WLC/ISE issue as it works with other devices
Solved! Go to Solution.
08-31-2020 04:38 PM
Based on the output provided, I can see below error msg and then client go through the association process again and again. If there is an opportunity, I would test the same configs with 8.10.130.0 WLC code version and check you have the exact same issue.
Did not find more specifics about the given error msg on Cisco.com
Rasik
08-31-2020 04:38 PM
Rasik
09-01-2020 06:11 AM
I'll give it a shot since it's just on my test controller.
09-01-2020 08:54 AM
Well, looks like 8.10.130 worked, so the fun part is I now have to look at and test a software upgrade also. I did have to laugh that a roomba worked fine with iPSK, but not an actual Cisco phone.
09-01-2020 03:18 PM
Good to hear it works in 8.10.130.0. If you ever hit weird issues like this it is always good to test with another code as most probably issue could be a software defect.
Rasika
