IPv6 address is not send over WLan
ilgorro2010
Hi!
My Cisco router is working fine with Ethernet and IPv6. There is a “little” problem concerning the promotion of IPv6 addresses under WLan. When I’m using WLan the router is not providing any IPv6 addresses, only IPv4. Do you have any clue why the router is not promoting the IPv6 addresses.
btw. I will post the config later on, when I’m at home.
Cheers
dancampb
Level 7
Level 7
What are you using for wireless, a controller, autonomous AP, or integrated AP?
If its a controller IPv6 is not natively supported yet.  It will bridge IPv6 if you enable support for it but the client will still have to run a dual stack (IPv4 and IPv6).
It´s an integrated AP!
Here is the Code:
gateway#sh ver
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(15)T11, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Thu 29-Oct-09 12:35 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YI2, RELEASE SOFTWARE
gateway uptime is 8 weeks, 13 hours, 17 minutes
System restarted at 20:04:22 MET Thu Apr 29 2010
System image file is "flash:c870-advipservicesk9-mz.124-15.T11.bin"
bridge irb
dot11 ssid v6gregor
   vlan 2
   authentication open
   authentication key-management wpa
   wpa-psk ascii 7 1407051D5A03382E232721
ip dhcp pool wlan_v6
   network 10.11.60.0 255.255.255.0
   default-router 10.11.60.1
   domain-name ipv4.at
   dns-server 195.70.224.45 62.218.28.35
interface Dot11Radio0
description Provisioned by CSM (private interface)
no ip address
load-interval 30
no dot11 extension aironet
encryption vlan 2 mode ciphers tkip
encryption vlan 3 mode ciphers tkip
encryption vlan 1 mode wep optional
ssid daham
ssid open
ssid v6gregor
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
power local cck 17
power local ofdm 17
power client 17
channel 2432
station-role root
rts threshold 2312
antenna receive right
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.2
encapsulation dot1Q 2
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface BVI1
ip address 10.10.10.1 255.255.255.0
ip nbar protocol-discovery
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1300
ipv6 address 2001:938:DAD:400::1/64
ipv6 enable
ipv6 nd prefix 2001:938:DAD:400::/64
ipv6 nd router-preference High
interface BVI2
ip address 10.11.60.1 255.255.255.0
ip nat inside
ipv6 address 2001:938:DAD:800::1/64
ipv6 enable
ipv6 mtu 1300
ipv6 nd prefix 2001:938:DAD:800::/64
ipv6 nd managed-config-flag
ipv6 nd ra interval 60
