Is AP synchronization with C9800 in N+1 setup possible?
Tobias Heisele
When an AP is joining it's primary WLC and gets it's tags assigned, is there any chance of syncing these AP definition to a secondary/backup wlc?
Even if both WLCs are identical configured regarding tags and policies, each AP that joined the primary WLC needs manually added the backup wlc. Otherwise in case of a failover, the AP will get default-tags, since that information is not (like the AP-Group) stored in the AP.
Rafael E
Once configured on the primary WLC you need to save the tags on the AP using the following command:
ap name <AP name> write tag-config
If you move this AP and if tags exist on the N+1 WLC then AP will keep the configuration
Saludos,
Rafael - TAC
Rafael E
Saludos,
Rafael - TAC
as a workaround is this a fine solution. A solution via Gui and an "all" ap command would be nice :-)
Indeed. I know there's is something we are working on now to make it better as to what we currently have.
You can follow up with your account team so they can give you further information :)
Saludos,
Rafael - TAC
