Is there a simple way to do url redirect on open SSID
Hello
I have an open SSID on 5508 controllers - configured as anchors  and need to redirect wireless clients to the wireless help page automatically once they have connected and opened their browser.
Is there a simple way of doing this?  I've read all throught the web auth and passthrough discussions on here but nothing seems to be quiet right for me - unless I am completely missing somthing....
Any advice gratefully received
5 Replies 5
Scott Fella
You can redirect them to and external webpage that would host your help page. Or you can try to modify the html to pop open a new page when you click on accept.  That you will have to play with though.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Thank you for your reply Scott
I have tried configuring Conditional Web Redirect under the layer 3 security tab of the WLAN but get the following message
invalid security policy [Auto-Anchor COND-WEB-REDIR]
Do you know if there is another way I can do it?
You should be able to set this on the anchor wlc, but you need to defineeither a webauth or passthrough.
Security > Web Auth > Web Login Page > Redirect URL after login
Scott
-Scott
Take a look at this doc:
https://supportforums.cisco.com/docs/DOC-13954#Conditional_Web_Redirect
Scott
-Scott
Scott
Thanks very much for all your help,
I've got the web passthrough working I would have really liked to have no 'accept' page and redirect straight to the wireless help site.  In the end I cusomized the login.html page to show a bit of wireless help info then changed the 'accept' button to say 'more help' then redirect to the wireless help site when clicked.  A big learning curve especially as I didn't realise that uploading the webauth bundle overwrites everything on the WLC existing webauth bundle....
All devices are working ok apart from Ipads  - they load the 'accept' page but when they click accept (or more help as ours is configured)  the ipad drops the connection to the help SSID and tries to connect a different SSID
I don't suppose you have seen this rt heard of anyone else having this problem?
Also I've seen a few of your posts sent from an ipad and noticed this
https://supportforums.cisco.com/thread/2155530
Does this mean we could have no 'accept' page and just redirect if I upgrade to 7.2.110.0
Once again thanks for your help Scott
