06-21-2018 10:56 PM - edited 07-05-2021 08:46 AM
Hi All,
Is there a way to use AIR-CAP2702I-E-K9 in Hong Kong. I understand that it's regulatory domain is not meant to be used in Hong Kong but I just need if there is a way this AP can be used in HK by applying certain configuration in WLC.
Thanks!!
Solved! Go to Solution.
06-21-2018 11:33 PM - edited 06-21-2018 11:34 PM
I strongly recommend you don't. WHEN (not "if") by the authorities there will be a fine (and the fine is usually higher than the price of the AP).
06-22-2018 12:03 AM
if you enable multiple country code (europe and hongcong) then...
One thing to remember when running multiple country codes is that you always run the lowest common setting. Only common channels will be allowed. Power will also be curtailed to the most common one.
Dont forget to rate helpful posts
06-21-2018 11:05 PM
You should not use diff. regulatory domian AP in your country.
Regulatory Domain for Hongcong is -S-
To(2702I-E-K9) make it work....... you should configure any Europian country code on cisoc wlc then -E- domain AP will join and it will work.
Dont forget to arte helpful posts
06-21-2018 11:11 PM
06-21-2018 11:28 PM - edited 06-21-2018 11:29 PM
which country is configure don wlc ?
and whcih regulatory domian AP you have ?
06-21-2018 11:48 PM
06-21-2018 11:50 PM
Again.. as Leo and I mentioned earler that you should not use wrong/diff AP domain AP.
Now i was asking for old APs regulatory domain (which are alredy assoicated to wlc )!!
06-21-2018 11:56 PM
06-22-2018 12:03 AM
