Is there a WEB UI on a CBW140AC via the LAN interface?
Gilfrid63
Is it possible to access the web UI via the LAN on a CBW140AC?
The only port that I can see open is the SSH port 22
I can see no way of configuring the AP to allow the WEB UI on the LAN either HTTP (80) or HTTPS (443).
So how does one remotely manage these APs?
11 Replies 11
marce1000
 - There should be  , what kind of errors or problems are you encountering when trying to use the GUI ?
 M.
Gilfrid63
Thank you Marce, you have responded to questions about this before
The key is in the word LAN.  The GUI is only accessible from the WLAN, so you have to be a wireless client of the AP to get access to the GUI. What I expected (and need) is some way to remotely manage the AP and I had thought that this would be via a WEB GUI on the LAN interface.
To be clear. If I have a PC with a wired interface on the same LAN as the AP it is not possible to access the WEB GUI. In fact the only port open on the WEB GUI is port 22 (SSH).
Thanks again for answering.
  - Simply try it anyway , 'without' the info concerning the open ports : what happens and or what do you notice in the browser ?
 M.
Gilfrid63
I have tried it, that's how I know it doesn't work!
  I  am glad for your reply , but I would like to know exactly what the browser returns ,
 M.
Gilfrid63
This site can’t be reached
192.168.0.221 took too long to respond.
Try:
ERR_CONNECTION_TIMED_OUT
Gilfrid63
Not really a surprise as no port at that address other than 22 is open.
                  >...Not really a surprise as no port at that address other than 22 is open.
  - Make sure that no intermediate (Intranet) firewalling restrictions are blocking access to the https port (443)
    You can for instance investigate with :  %
nmap --reason CBW140AC
                          Or try from a host on the same subnet as the CBW140AC
 M.
Gilfrid63
There is no WEB interface on the LAN for CBW140AC - that's the answer.
End of conversation.
                 >....There is no WEB interface on the LAN for CBW140AC - that's the answer.
  - So why ask then (?), the latter reasoning proofs that your unable to iterate  , deep walk through and in the end resolving a problem.
  M.
marce1000
                                                    - Have a Happy New Year !!
                  https://www.cisco.com/web/fw/tools/cisco-business/emulators/wireless/10-7-1-0/index.html
  M.
