is there any limitation of firmware or hardware for QoS configuration (4400 controller & 1252 AP's)
vinodjad1234
Level 2
Level 2
Hi Experts,
Before proceeding for adding AP model 1131 and 1252 into my set-up , I need to know whether any limitation of firmware or hardware for QoS configuration in wireless set-up .
I have 4400 controller and 1130 & 1250 AP models.
Rasika Nayanajith
Hi Vinod,
Since you have 4400 controllers, you can run upto WLC 7.0.x code. Refer this for more detail
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
there is no specific limitation to 1131/1252 AP model as such, everything is WLC software dependent.
From later software 7.4.x,7.6.x,8.x, lots of improvement for QoS configuration & bandwidth control, but since your controller is old hardware, you cannot have those latest features.
here is a reference post on how QoS works in wireless environment
http://mrncciew.com/2012/11/28/understanding-wireless-qos-part-1/
Rasika
*** Pls rate all useful responses ****
