IS WLC C9800 compatible with Cisco AP1852I
Vencola
Hi everyone,
what are the list of Access points compatible with WLC C9800L, is it compatible with AP1852I-I-K9
Arshad Safrulla
Hi ERC IT,
As of now 1852 is compatible with any 9800 platform running latest IOS-XE code (17.6.X). All the Wave2 platforms are give EOS & EOL dates. So WiFi6 Catalyst AP's will be the way forward.
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1850-series-access-points/aironet-1850-series-access-points-eol.html
You can find the supported AP models as per the IOS-XE code and platform in the below link.
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#:~:text=for%20AireOS%20Releases.-,Supported%20Access%20Points%20in%20Cisco%20Wireless%20Software%20Releases,-Table%201%20and
Arshad Safrulla
Hi ERC IT,
