What kind of device information I can collect by MDM integartion with ISE.
You Can collect the below information with MDM integration with ISE 1.2
1. Device Manufacturer
2. Device Model
3. Phone IMEI
4. Serial#
5. OS version
6. MAC address.
Ravi,
Earlier this year I was told that the ETA for ISE 1.2 was April, is there an updated ETA?
Martin
Mid-July I believe.
ISE 1.2 is now delayed and is not shipping yet. We will let you know when it ships. SNS Appliance with 1.2 software will not be available until end of August. Until then, you must order SNS appliance with 1.1.4 and then manually upgrade it to 1.2. Existing customers with existing appliances can download 1.2 from the CCO Software Download page.
Hello Ravi,
Thanks for your help. I appreciate your knowledge.
ISE Release 1.2 delivers integration between Identity Services Engine and MDM platforms, which can ensure that all mobile devices are compliant with security policy before they are allowed to access the network. This feature enables posture compliance assessment and network access control of mobile endpoints attempting to access the network. The solution also performs ongoing posture checks to ensure that devices remain compliant and that the correct network access level is maintained. The specific posture attributes collected by MDM partner platforms for compliance and access policy enforcement in the Identity Services Engine are:
• Is the mobile device registered with MDM?
• Does the mobile device have disk encryption enabled?
• Does the device have PIN-Lock enabled?
• Has the device been jail-broken/rooted?
In terms of global compliance, posture compliance decisions may be made by the MDM platform instead of the Identity Services Engine. In this scenario, additional attributes such as blacklisted applications or presence of an enterprise data container may be checked. The MDM platform simply informs the Identity Services Engine if a device is in compliance, then the Identity Services Engine enforces the appropriate network access policy.
This integration brings great value to MDM customers as it automates to the device registration process. As MDM solutions are network-blind, they can't detect a new device when it connects to the wireless network, so the administrator needs to send a notification to the users who wish to enroll their devices. With ISE integration, device enrollment is done automatically when users connect their device to the Wi-Fi network.
SNS appliances are now available with ISE 1.2 in SNS-3415-K9 and SNS-3495-K9 appliances.
