ISE Guest Access Bandwidth Management Problem
m.soleimani
I was deployed ISE Guest Access Service with Cisco ISE 2.4 and Cisco WLC 8.5, I want to limit client bandwidth in this service,So i used authorization profiles via cisco ISE, i set advanced attributes like attachment files, when client connect to Wireless Network this attributes passed to the wlc but dosent work correctly (it means that QoS just applied on Up Stream )
Some idea.. someone can help me.
Thanx in advance
Aire-Real-Time-Bandwidth-Average-UpStream-Contract = 4000
Aire-Data-Bandwidth-Average-DownStream-Contract = 4000
Aire-Data-Bandwidth-Burst-UpStream-Contract = 4000
Aire-Real-Time-Bandwidth-Burst-DownStream-Contract = 4000
Aire-Real-Time-Bandwidth-Average-DownStream-Contract = 4000
Aire-Real-Time-Bandwidth-Burst-UpStream-Contract = 4000
Aire-Data-Bandwidth-Average-UpStream-Contract = 4000
Aire-Data-Bandwidth-Burst-DownStream-Contract = 4000
hslai
I would suggest to turn on client debug and check the debug messages in WLC. I am moving this to wireless forum as this is more specific to wlc deployments.
the Attributes that I set them in ISE Authorization Profile passed to WLC, and in WLC>MONITOR>Clients>Quality of Service Properties I could see These Attributes, but the QoS Limitation just applied on one way of client connection(upload Traffic). Does anyone have this problem?
is anyone can help?
HI hslai
I've Attached my debug messages, would you Please check it?
