ISE Portal: change guest flow
SondreSandberg
Utilizing ISE 3.1 and using the portals for CWA (centralized web auth).
Does anybody know if it is possible to change the guest flow in the portal?
This is what I want to achieve:
Default landing page should be the "self registration" page, not the "login" page.
6 Replies 6
balaji.bandi
just to be clear even the user already register you would like to send the user to self registration. ?
personally i believe you get Login page, if the user not register will go to registration portal, if the register user can login using Login credentials, that will right form i guess.
BB
Charlie Moreton
Yes!  The instructions are here:  Login page auto-redirect to create an account page
Exactly what I was looking for, thank you!
I am also looking for a way to autofill the created username and the user has to enter the received password.
Do you perhaps hold a script for that?
I don't believe that's possible.
