Issue: Finding domain controller
erikdraganov
Community Member
I have been noticing that some notebooks equipped with cisco a/b/g adapters are presenting problems in the last step of LEAP authentication (Finding domain controller). This issue suddenly appears after installing Checkpoint SecuRemote (VPN Client). Even if I shutdown the vpn client, I am not able to find a domain controller unless I'm connect to a wired lan. One solution to this problem is disabling the Checkpoint Securemote protocol under wireless connection properties. Unfortunaly, some users use the vpn through a wireless connection, so I need then working together! Any ideias on how I can make my card find the domain controller! ehehhe!
0 Replies 0
