Issue flexconnect mode
ntlong3
Frequent Visitor
Frequent Visitor
There are two modes in Flex-connect deployments and these modes are: connected mode and standalone mode.when APs lose connection to the Controller, the APs will run Standalone mode.  However, some AP devices can join the controller, but others cannot. It has switched to EWC mode. Can someone please explain this to me and give me a solution ?
7 Replies 7
Mark Elsen
  - Make sure that involved APs can do CAPWAP only and or if needed convert them as explained in :
                   https://www.cisco.com/c/en/us/support/docs/wireless/embedded-wireless-controller-on-catalyst-access-points/215303-embedded-wireless-controller-conversion.html#toc-hId-1622399608
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
yeah,  i tried this way, which is to convert ewc mode to capwap mode. But command ap-type capwap sentence doesn't execute
                         >....But command ap-type capwap sentence doesn't execute
                    You may need to switch to the underlying AP shell first as explained in
 https://www.cisco.com/c/en/us/support/docs/wireless/embedded-wireless-controller-on-catalyst-access-points/215303-embedded-wireless-controller-conversion.html#toc-hId--865113225
 M.
 You are not wrong but this could be like this:
 There are 2 types of image the AP can support:  Capwap mode or standalone mode (now a days called mobility express /EWC)
  In capwap mode, it can be as local mode or flexconnect mode.
 In flexconnect mode it can be in connected mode or standalone mode. But this standalone mode can not be confused with the standalone mode x capwap mode.
 If your AP is running a EWC, this means you need to convert it to capwap mode first. Then, after that you can join it to the WLC as local mode or flexconnect mode.
yeah, when ap loses connection to controller and i know that it is running ewc mode. I tried the ap-type capwap command, but it doesn't seem to exist. And
How do we know that the Ap has an ewc image when connecting to the controller?
Use the command show version
As @Mark Elsen already explained above the command must be executed from the AP CLI not the EWC CLI.
Use "wireless ewc-ap ap shell username <admin>" to access the AP CLI from the EWC CLI.
Note you may have configured a different AP username that is not admin so you will use whatever credentials you configured for the AP.  The Cisco default will be admin and Cisco123
You can also disable EWC through option 43: https://www.cisco.com/c/en/us/products/collateral/wireless/embedded-wireless-controller-catalyst-access-points/white-paper-c11-743398.html#Conversion but note https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwc75102
And to permanently remove the EWC software so that it cannot ever re-activate you should re-flash the AP using the procedure at https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9120axi-access-point/217537-repairing-c9120-c9115-access-points-from.html
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
