Issue Wireless IP Phone 8821
csantiago11
Beginner
Beginner
I just received the new Wireless IP Phone model 8821. when i try to register the phone to Cisco Unity Express, get the next message in the phone:
tftp error: wlan rootca.cer.sng
tftp error: AppDialRules.xml
XMLDefault.cnf.xml(TFTP)
File not found: SEPF8A5C59C7320.cnf.xml
have any idea, how to resolve that issue?
csantiago11
Beginner
Beginner
You can configure in fast-track mode
The configuration is:
voice register pool-type  8821
 xml-config maxNumCalls 2
 xml-config busyTrigger 1
 phoneload-support
 reference-pooltype 9971
voice register pool  16
 busy-trigger-per-button 2
 id mac xxxx.xxxx.xxxx
 type 8821
 number 1 dn X
 dtmf-relay sip-kpml
 codec g711ulaw
Recognize Your Peers
