issue with configuration (1142) standalone
ahmed_843
HI all
I have two issue with this configuration :
First :I tray to login to my SSID thru the Laptop ( you can find the Password  in the configuration) but the laptop cannot recognize the Password or  (encryption)
Second : after making the Switch port as trunk port i lost the communication with the accuses point ( cannot ping or login )  but still the accesses point provide the SSID
and the is the configuration :
ap6#show run
Building configuration...
Current configuration : 3200 bytes
! Last configuration change at 00:47:19 UTC Thu Mar 4 1993 by cisco
version 15.2
no service pad
service password-encryption
hostname ap6
logging rate-limit console 9
enable secret 5 $1$chvK$NWIkf9vixVYo1y3OcXNqh0
no aaa new-model
no ip routing
dot11 syslog
dot11 ssid AMCO_3F1
   vlan 7
   authentication open
   authentication key-management wpa version 1
   mbssid guest-mode
   wpa-psk ascii 7 itadmin0001amco123
dot11 ssid AMCO_3F1_TEST
   vlan 1
   authentication open
   mbssid guest-mode
username Cisco password 7 062506324F41
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
encryption vlan 1 key 1 size 40bit 7 123456789012 transmit-key
encryption vlan 1 mode wep mandatory
encryption vlan 7 mode ciphers tkip
ssid AMCO_3F1
ssid AMCO_3F1_TEST
antenna gain 0
mbssid
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.2
encapsulation dot1Q 7
no ip route-cache
bridge-group 7
bridge-group 7 subscriber-loop-control
bridge-group 7 spanning-disabled
bridge-group 7 block-unknown-source
no bridge-group 7 source-learning
no bridge-group 7 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
ssid AMCO_3F1
ssid AMCO_3F1_TEST
antenna gain 0
no dfs band block
mbssid
channel dfs
station-role root
interface Dot11Radio1.1
no ip route-cache
bridge-group 1
interface Dot11Radio1.2
no ip route-cache
bridge-group 7
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.2
no ip route-cache
bridge-group 7
interface BVI1
ip address 192.168.7.21 255.255.255.0
no ip route-cache
ip default-gateway 192.168.7.11
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
For First: I would delete this on the radio interfaces:
     because the Radio Clients will never understand VLAN tagging, right?
For second, whats your trunk config, the management VLAN needs to be untagged, called native in your case here.
regards,
Sebastian
