Issue with setup Single Point Setup, 2 devices Cluster-Controller
zuyd32724
Visitor
I have 2 Cisco WAP371 devices.
1. WAP371-E-K9 V03
2. WAP371-E-K9 V02
Doesnt matter if I setup the first or the second one first and join the other. When I join the 2nd device its not displayed as a device in the master. When checking the SPS both devices are marked Yes with Cluster-Controller
Firmware has been upgrade on both to 1.3.0.7
1st
Single Point Setup allows WAP371-A-K9 access points to propagate settings.
Single Point Setup: Enabled
Access Points detected in Cluster: WLAN_Cluster2
LocationMAC AddressIP AddressCluster-PriorityCluster-Controller
home00:22:44:66:88:00192.168.178.1500yes
To change your clustering options, click "Disable Single Point Setup".
Enter the location of this AP.
Enter the name of the cluster for this AP to join.
Cluster Name: (Range: 1-64 Characters)
Clustering IP Version: IPv6  IPv4
Cluster-Priority: (Range: 0-255, Default: 0)
2nd
Single Point Setup allows WAP371-E-K9 access points to propagate settings.
homeA0:55:4F:67:51:F0192.168.178.240yes
When joining its mentioned successful added.
Can somebody please help me.
pieterh
my guess is the AP's each joined it's own cluster (with just a single AP)
The cluster name is not sent to other WAPs so you must configure the same name on each device that is a member.
check the cluster-name match exactly! (try a name with all lowercase)
you can check the web-interface to show how many AP's are connected in a cluster
thanks for the reply.
They are both mentioned with only 1 AP.
I changed the Cluster name to, still joining isnt done. This is the reponse message i receive after joining
Device Setup Complete
