07-03-2013 01:53 AM - edited 07-04-2021 12:20 AM
Hello evrybody,
I'm new at this domain and my project is to deploy a secure wireless, failing to use an ISE for many reasons, I'm working with an WLC 5508 and to do the authentication I used our Freeradius but there are some weird bugs that I faced and I would like to know your thoughts on it:
I added the wlc on the radius as client,after that when I test the connexion with iphone it displays the portal and I entred my radius login then I had the google page (normal and correct autentication). Then when I walked away from the access point, and when I come back he asked me to put my login again, I hadn't this issue with my laptop.
I would say that mac address isn't registred.
Thanks in advance for any suggestion
07-03-2013 03:48 AM
Hi Sali,
Any reason for you to think this radius server issue?
Can you verify encryption are you using on your SSID? Is it WPA/TKIP or WPA2/AES? Ensure that you choose either of them and not both of them and try the connectivity again.
Hope that helps
Najaf
Please rate when applicable or helpful !!!
07-03-2013 05:20 AM
Hi Najaf,
Now it works correctly, I have no explication for this, very strange!
But I have another question, I'll create a new topic in few minutes
07-03-2013 05:22 AM
Glad to know that things are working as expected :-)
