Issues with 2nd VLAN on WLC 4408
nix-patheon
HI all,
I have been experiencing issues trying to connect to other devices outside of the vlan defined on the controller. I have the following set up on the controller:
Interfaces:
Name          VLAN ID          IP Address          Interface Type          Dynamic AP Management
ap-manager     100              192.168.100.12         Static               Enabled
int_vlan10        10               192.168.8.3               Dynamic          Disabled
int_vlan20        20               10.201.24.3               Dynamic          Disabled
management    100             192.168.100.11          Static
service-port                         192.168.1.1
virtual                                 1.1.1.1
VLAN 10 connects through a fibre switch to an ADSL router and works ok, VLAN 20 connects directly to an access port on my core switch. I can ping anything within the subnet (actually only the wlc and core routed interfaces) of VLAN 20 but not outside (I want to authenticate WLAN users against an LDAP server which is directly connected to the core also). There are no ACL's on either the wlc or the core switch. Controller is LAG mode, and I have defined the specific interface for the SSID.
I would really appreciate any suggestions on why it's no working.
Thanks.
Chris Illsley
Level 3
Level 3
The controller is in LAG mode, you need to remove this so the controller doesn;t try to aggregate the connections.
Once you have done this you can assign VLAN interfaces to the port.
Chris
Chris Illsley
Level 3
Level 3
Chris
Thanks Chris. You are the man!
