Issues with Aironet 1142 and Iphone/Ipad connecting
David Thomason
I have 3 WLAN's setup, one using RADIUS, another using WPA2-Personal, and another one with Open Authentication.  I can connect to them fine with a windows machine or even a mac.  The iphone or ipad can only connect to one.  So if i wan't to connect to another I have to forget that network then restart the wifi service on the iphone or ipad.  The 3GS will not connect to the WLAN with Open Authentication whatsoever.
George Stefanick
Do you have CCKM enable on any of the WLANs? Apple devices will not connect to WLANs with CCKM.
Also are you using a WLC?
Only using PSK. Yes I'm using a 2504 WLC.  I'm able to connect to one SSID but when I want to connect to another I have to forget the first network in order to join another SSID.
