Issues with WebGUI on Cisco WLC 5508/7.4.110.0
Amandeep Mann
I am facing a weird issue with accessing few of the GUI pages in WLC intenal portal, i.e. it works fine on few, but just waits eternally or even need to re-login when trying to access i.e. WLAN's>Edit any specific wlan OR Editing any AP in Wireless>All AP's>Specific AP.
Had tried rebooting the WLC/regenerating the web auth. cert. /etc.
Scott Fella
You should be on v7.4.130.0 as the version you are on has other issues.  When on v7.4 or later, you also need to make sure you have upgraded the FUS to 1.9.0.0.  Also look at the browser for any saved certificates since your are regenerating the cert which can be an issue also.  Try a different browser and see if the issue persist or not.
-Scott
-Scott
Scott Fella
-Scott
-Scott
