IW3702AP
nandini-roy
Community Member
IS THE ABOVE-MENTIONED INDUSTRIAL GRADE ACCESS POINT ABLE TO BE USED AS A SELF-MODE CONTROLLER?
CAN IT BE USED WITH CATALYST'S ACEESS POINT OF THE EWC MODEL?
WILL IT BE COMPATIBLE WITH THE 9800 CONTROLLER?
Please do help with above-mentioned questions
Mark Elsen
  - Ref : https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
            Look for IW3702 with find in browser for all info's on compatibility
   ===> Added : this AP can be used in autonomous mode too :
                                    https://software.cisco.com/download/home/286287624/type/284180979/release/15.3.3-JPN4
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Rasika Nayanajith
No, It cannot operate as Mobility Express (name Cisco used for self mode controller on 11ac wave2 APs). Refer below table. It can connect to a another Mobility Express AP act as primary.
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/810/release_notes/b_ME_RN_810.html
Yes
Yes, refer the compatibility matrix shared by Marce.
Rasika
*** Pls rate all useful responses ***
