Keep losing association when changing when trying to hardcode as root
nygenxny123
Level 7
Level 7
I have a pair of aironet 1400's which im setting up as point to point. When I leave everything in autoinstall. Bridge A will always be the parent, and B the non-root.
However when I try to change A to root bridge and B to non-root brige, they no longer associate with each other. No
authentication currently, excpept basic WEP
I also dont understand why B is never taking the parent role..even when i reset bridge a
Not applicable
Reset the bridges. Disable the Radios. Configure A as Non-root , B as Root . Then enable the Radios and check if this works. Because the settings made during autoinstall mightn't have got erased.
