Keep one AP from offering SSID
Chris Jones
I've got two WCS and two WLCs and about 75 lightweight APs.  I've got 3 SSIDs.  One guest, and two production networks.  I have an area of the building where I do not want the guest SSID to be available.  How can I prevent one AP from accepting clients on the guest SSID, or how can I filter it so that one AP doesn't have the guest SSID as an option?
Chris
Hi Chris,
What you need is something called AP GROUPS. Where by allowing you to shape what SSID is used on what ap.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008073c723.shtml
__________________________________________________________________________________________
Chris Jones
Oops, that's one WCS and Two WLCs. :-)
Hi Chris,
Thank you for the link!  I thought it should have that abillity, but I just didn't see it there.
Thanks!
     Chris
I created a video on my blog dealing with AP groups that you might find helpful
http://www.my80211.com/cisco-wlc-labs/2009/3/22/cisco-ap-group-nugget.html
Thanks for supporting the rating system!
