KPI of Wireless network
balsutiev.s
Dear sirs,
If there any Cisco recommendations or best practice documents on Key Performance Indicators of wireless network such as % of errors in Radio by AP, % of data passed trough AP, % of succesfull associations of users under each AP, % of unsuccesfull associations of users under each AP and so on?
Thank you in advance!
5 Replies 5
wong34539
Level 6
Level 6
In Cisco website you will find only Data Sheets like these,
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_data_sheet09186a00800937a6.html. Probably your local cisco representative could get you this document.
ecayli123
Looking the same
abwahid
Level 4
Level 4
Please refer the below similar post
https://supportforums.cisco.com/discussion/11334841/wlan-monitoring-tools
Leo Laohoo
Personally, my KPI are the following:
1.  AP uptime;
2.  Total amount of AUTHENTICATED vs associated clients per day.  (I will start raising my eyebrows if authenticated clients go up >30 wireless clients per AP.)
3.  AP interface speed should be 1 Gbps and NOT 100 Mbps (or less).
4.  Wireless interference detected.
Hi Leo Laohoo!
Do you have the Oids for the KPis you mentioned?
Regards!
