Lan connectivity Issue on autonomous AP with throttles
cerisier
  I encounter a strange problem on several AP 1242 in version 12.4(25d)JA1 of a customer :
  He has 10 autonomous AP covering a factory and is using them for laptop connectivity and TOIP with mainly 7921 Cisco Wifi Phones.
  The phones are configured to use only 802.11a.
  The APs loose LAN connectivity randomly and therefore the clients don't work anymore.
  The AP are connected on a 2960 and a 3560 wich are in turn connected on a 3750 wich route the trafic.
  After checking spanning-tree no loops are present.
  When I check the counters on the AP involved I see the "trhottles" and "ignored" counters incrementing on the fa0 link of the AP impacted wich mean I think it can't handle the incoming traffic. This incoming traffic seems not to be too big however. I can see drops on the switch interface connecting the AP.
There is a lot of roaming on the AP due to people walking in the factory with their wifi phones.
Here is a view of the fa0 counters :
AP1242-LOGIST#sh int fa0
FastEthernet0 is up, line protocol is up
  Hardware is PowerPCElvis Ethernet, address is 001d.a1ce.26e2 (bia 001d.a1ce.26e2)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Full-duplex, 100Mb/s, MII
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/160/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 81000 bits/sec, 53 packets/sec
  5 minute output rate 29000 bits/sec, 26 packets/sec
     7447113 packets input, 674891974 bytes
     Received 286839 broadcasts, 0 runts, 0 giants, 549631 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 549631 ignored
     0 watchdog
     4422100 packets output, 609868806 bytes, 0 underruns
     0 output errors, 0 collisions, 4 interface resets
     1 unknown protocol drops
     0 lost carrier, 0 no carrier
  Here is a small part of logs concerning roaming, i don't see errors or log indicating that something is wrong nor in the switches log :
Jun  6 12:57:27.007: %DOT11-6-ASSOC: Interface Dot11Radio1, Station SEP001E4A3EE15D 001e.4a3e.e15d Associated KEY_MGMT[WPAv2 PSK]
Jun  6 12:57:42.499: %DOT11-6-ASSOC: Interface Dot11Radio1, Station SEP588D09D3A92B 588d.09d3.a92b Reassociated KEY_MGMT[WPAv2 PSK]
Jun  6 12:58:02.620: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 588d.09d3.a92b Reason: Sending station has left the BSS
Jun  6 12:58:03.653: %DOT11-6-ASSOC: Interface Dot11Radio1, Station SEP588D09D3A92B 588d.09d3.a92b Reassociated KEY_MGMT[WPAv2 PSK]
Jun  6 12:59:15.564: %DOT11-6-ROAMED: Station 588d.09d3.a92b Roamed to 001e.134c.5a50
Jun  6 12:59:15.564: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 588d.09d3.a92b Reason: Sending station has left the BSS
Jun  6 12:59:41.905: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 442b.0355.ab28 Reason: Previous authentication no longer valid
Jun  6 12:59:54.728: %DOT11-6-ASSOC: Interface Dot11Radio1, Station SEP442B0355AB28 442b.0355.ab28 Associated KEY_MGMT[WPAv2 PSK]
Jun  6 13:01:12.541: %DOT11-6-ASSOC: Interface Dot11Radio1, Station SEP588D09D3A92B 588d.09d3.a92b Reassociated KEY_MGMT[WPAv2 PSK]
Jun  6 13:02:35.841: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 001e.4a3e.d875 Reason: Previous authentication no longer valid
Jun  6 13:02:36.489: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   ec85.2f7c.c837 Associated KEY_MGMT[WPAv2 PSK]
Jun  6 13:03:29.256: %DOT11-6-ROAMED: Station 588d.09d3.a92b Roamed to 001e.134c.5a50
Jun  6 13:03:29.256: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 588d.09d3.a92b Reason: Sending station has left the BSS
Jun  6 13:04:32.754: %DOT11-6-ASSOC: Interface Dot11Radio1, Station SEP001E4A3ED875 001e.4a3e.d875 Associated KEY_MGMT[WPAv2 PSK]
Jun  6 13:06:47.858: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 001e.4a3e.e15d Reason: Previous authentication no longer valid
Jun  6 13:07:18.107: %DOT11-6-ROAMED: Station 001f.6c7a.5101 Roamed to 001d.a2bb.15b0
Jun  6 13:07:18.107: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 001f.6c7a.5101 Reason: Sending station has left the BSS
Jun  6 13:07:38.109: %DOT11-6-ASSOC: Interface Dot11Radio1, Station SEP588D09D3A92B 588d.09d3.a92b Reassociated KEY_MGMT[WPAv2 PSK]
Jun  6 13:07:42.031: %DOT11-6-ROAMED: Station 588d.09d3.a92b Roamed to 001e.134c.5a50
Jun  6 13:07:42.031: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 588d.09d3.a92b Reason: Sending station has left the BSS
Jun  6 13:07:46.489: %DOT11-6-ASSOC: Interface Dot11Radio1, Station SEP001F6C7A5101 001f.6c7a.5101 Reassociated KEY_MGMT[WPAv2 PSK]
Jun  6 13:08:27.712: %DOT11-6-ASSOC: Interface Dot11Radio1, Station SEP588D09D3A92B 588d.09d3.a92b Reassociated KEY_MGMT[WPAv2 PSK]
Jun  6 13:08:44.502: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 588d.09d3.a92b Reason: Sending station has left the BSS
Jun  6 13:08:44.572: %DOT11-6-ASSOC: Interface Dot11Radio1, Station SEP588D09D3A92B 588d.09d3.a92b Associated KEY_MGMT[WPAv2 PSK]
Jun  6 13:08:56.778: %DOT11-6-ROAMED: Station 588d.09d3.a92b Roamed to 001e.134c.5a50
Jun  6 13:08:56.779: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 588d.09d3.a92b Reason: Sending station has left the BSS
Jun  6 13:09:17.874: %DOT11-6-ROAMED: Station 001f.6c7a.5101 Roamed to 003a.9a92.8d70
Jun  6 13:09:17.874: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 001f.6c7a.5101 Reason: Sending station has left the BSS
The AP are configured as follow :
Current configuration : 5184 bytes
! No configuration change since last restart
version 12.4
no service pad
service password-encryption
hostname AP1242-LOGIST
logging rate-limit console 9
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone gmt+1 1
clock summer-time gmt recurring last Sun Mar 2:00 last Sun Oct 3:00
dot11 syslog
dot11 vlan-name Data vlan 11
dot11 vlan-name Voix vlan 14
dot11 vlan-name Webguest vlan 5
dot11 ssid WLAN_data
   vlan 11
   authentication open
   authentication key-management wpa
   mbssid guest-mode
   wpa-psk ascii 7 10600C0E261B173C252203797479633F371A29
dot11 ssid WLAN_voice
   vlan 14
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 080F49592A1500203B2D25567A7A7622263C0C
dot11 ssid Webguest
   vlan 5
   authentication open
   mbssid guest-mode
dot11 wpa handshake timeout 1000
dot11 arp-cache
dot11 priority-map avvid
dot11 phone
power inline negotiation prestandard source
class-map match-all _class_voice0
match ip dscp ef
class-map match-all _class_voice1
match ip dscp cs3
policy-map voice
class _class_voice0
  set cos 6
class _class_voice1
  set cos 3
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 11 mode ciphers aes-ccm
encryption vlan 14 mode ciphers aes-ccm
ssid WLAN_data
ssid WLAN_voice
ssid Webguest
mbssid
power client 17
channel 2472
station-role root
dot11 qos class voice local
    admission-control
    admit-traffic narrowband max-channel 75 roam-channel 6
dot11 qos class voice cell
    admission-control
no cdp enable
infrastructure-client
interface Dot11Radio0.5
encapsulation dot1Q 5
no ip route-cache
no cdp enable
bridge-group 5
bridge-group 5 subscriber-loop-control
bridge-group 5 block-unknown-source
no bridge-group 5 source-learning
no bridge-group 5 unicast-flooding
bridge-group 5 spanning-disabled
interface Dot11Radio0.11
encapsulation dot1Q 11
no ip route-cache
no cdp enable
bridge-group 11
bridge-group 11 subscriber-loop-control
bridge-group 11 block-unknown-source
no bridge-group 11 source-learning
no bridge-group 11 unicast-flooding
bridge-group 11 spanning-disabled
interface Dot11Radio0.14
encapsulation dot1Q 14
no ip route-cache
no cdp enable
bridge-group 14
bridge-group 14 subscriber-loop-control
bridge-group 14 block-unknown-source
no bridge-group 14 source-learning
no bridge-group 14 unicast-flooding
bridge-group 14 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid WLAN_data
ssid WLAN_voice
ssid Webguest
no dfs band block
mbssid
channel dfs
station-role root
interface Dot11Radio1.5
no ip route-cache
no cdp enable
bridge-group 5
interface Dot11Radio1.11
no ip route-cache
no cdp enable
bridge-group 11
interface Dot11Radio1.14
no ip route-cache
no cdp enable
bridge-group 14
interface FastEthernet0
no ip address
no ip route-cache
speed 100
full-duplex
no cdp enable
hold-queue 160 in
interface FastEthernet0.1
encapsulation dot1Q 1 native
no ip route-cache
no cdp enable
bridge-group 1
no bridge-group 1 source-learning
bridge-group 1 spanning-disabled
interface FastEthernet0.5
no ip route-cache
no cdp enable
bridge-group 5
interface FastEthernet0.11
no ip route-cache
no cdp enable
bridge-group 11
interface FastEthernet0.14
no ip route-cache
no cdp enable
bridge-group 14
service-policy input voice
service-policy output voice
interface BVI1
ip address 10.17.10.5 255.255.255.0
no ip route-cache
ip default-gateway 10.17.10.254
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
logging trap warnings
logging 10.15.51.115
no cdp run
bridge 1 route ip
line con 0
line vty 0 4
sntp server 10.15.1.50
sntp broadcast client
end
Does someone ever experienced a similar problem ?
When I shut radio interfaces they're is no more problems on the LAN. Can this be an overlapping coverage issue ?
Can someone please give me advices on how to troubleshoot this issue ?
Thank you in advance as I'm a bit stuck.
Best Regards,
Scott Fella
Well if your using WPA, you should be using TKIP. If you want to use WPA version 2, then you would use AES. Currently your using WPA/AES which is not standard. You should change it to WPA/TKIP or use WPA2/AES.
-Scott
     Hi Scott,
Thanks for your reply.
Do you think this can be the origin of the issue my customer encounters or is it only to be standard ? As this change will have to be made on all clients, if there is a chance it solves the problem I will do it ASAP, if not I will delay it in a less busy period :-)
Can the constant roaming associations and dissasociations overload the AP and make it stop responding on the LAN or is it only a throuhput problem ?
Thanks in advance for your answer.
Best Regards,
