Lan controller AIR-WLC4404-100-K9
malysak
Does the 4404 100 AP lan controller come
with the WCS software, or is that a seperate purchase?
How does this lan controller failover?  Does a backup controller need to be purchased?
Thank you!
Leo Laohoo
WCS is a separate purchase.
"Failover" is when you have more than one WLC or if you configure H-REAP,
When you have more than one WLC, when the WLC-A fails, the APs can swing to the next WLC that's been configured into them.  The downside is during the failover there's a 5-10 seconds of lost connectivity to the WLAN while the APs search for another WLC.
Configuring Failover Priority for Access Points
http://www.cisco.com/en/US/docs/wireless/controller/6.0/configuration/guide/c60lwap.html#wp1424902
When you configure H-REAP and, say, if you have only one WLC, when the WLC fails and the APs are not rebooted, the APs will function as if the WLC is still present.  This works even when you have VoWLAN.
H-REAP Modes of Operation Configuration Example
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807cc3b8.shtml
