LAP-1142N dose not registered with vWLC 7-3-101-0
I know that this topic is repeated so many times but still i did not get any help out of them. I am really greatfull to all of you guys who are making efforts here to help out others.
My Scanerio is that i have connected vWLC (On Vmware WS) with Cisco 3750L3 switch and my GW is FW. I have created 2 VLANs (VLAN10 and VLAN20) respectivly. I have a DHCP and DNS server, installed on Windows Server 2012 (VMwere) with scopes of DHCP, one for VLAN10 and one for VLAN20. all my devices are connected with VLAN10 (10.1.1.0/24) and only AP is connected with VLAN20 (10.1.2.0/24). Configured IP Helper command under VLAN 20 so it is communication with VLAN 10 and all network.
AP is getting DHCP IP from windows DHCP server and can ping to vWLC but its not pinging to DNS server and DHCP server which is on VLAN 10.
and when im trying to get registered AP with vWLC ( 7-3-101-0), it does not get registered and showing below logs.
*Jul 14 22:37:19.005: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul 14 22:37:19.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.1.120 peer_port: 5246
*Jul 14 22:37:19.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jul 14 22:37:19.014: %CAPWAP-3-ERRORLOG: Dropping dtls packet since session is not established.
*Jul 14 22:37:48.999: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2013 Max retransmission count reached!
*Jul 14 22:37:48.999: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 10.1.1.120 is reached.
*Jul 14 22:38:18.999: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.1.1.120:5246
*Jul 14 22:38:19.000: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jul 14 22:38:29.005: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul 14 22:38:29.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.1.120 peer_port: 5246
*Jul 14 22:38:29.000: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
Please look into above and advise me...
18 Replies 18
Solved the issue.. :)
All good.
Can you check firewall for any blocks?
(Cisco Controller) >show time
Time............................................. Sat Jul 15 13:33:08 2017
Timezone delta................................... 0:0
Timezone location................................
NTP Servers
NTP Polling Interval......................... 3600
Index NTP Key Index NTP Server NTP Msg Auth Status
1 0 10.1.1.99 AUTH DISABLED*
APa493.4c38.0b67#reload
Proceed with reload? [confirm]
Writing out t
*Jul 15 13:37:06.270: %SYS-4-PUPDATECLOCK: Periodic Clock update with ROMMON failed, because size left in ROMMON (4294967295), size needed (29), error code (-1)
*Jul 15 13:37:06.271: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.
*Jul 15 13:37:06.271: %LWAPP-5-CHANGED: CAPWAP changed state to DOWNhe event log to nvram...
using eeprom values
WRDTR,CLKTR: 0x87000800 0x40000000
RQDC ,RFDC : 0x80000035 0x00000209
using ÿÿÿÿ ddr static values from serial eeprom
ddr init done
Running Normal Memtest...
Passed.
IOS Bootloader - Starting system.
FLASH CHIP: Numonyx P33
Checking for Over Erased blocks
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x87000800, 0x40000000
RQDC, RFDC : 0x80000035, 0x00000209
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is up.
PCIE1: VC0 is active
PCIEx: initialization done
flashfs[0]: 62 files, 15 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 23254016
flashfs[0]: Bytes available: 9131008
flashfs[0]: flashfs fsck took 29 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: a4:93:4c:38:0b:67
Ethernet speed is 100 Mb - FULL duplex
Loading "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx"...#######################################################################################################################################################################################################################
File "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx" uncompressed and installed, entry point: 0x4000
executing...
enet halted
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C1140 Software (C1140-RCVK9W8-M), Version 12.4(21a)JA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 08-Jun-09 16:28 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 62 files, 15 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32385024
flashfs[1]: Bytes used: 23254016
flashfs[1]: Bytes available: 9131008
flashfs[1]: flashfs fsck took 6 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1142N-N-K9 (PowerPC405ex) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FGL1620S4Y9
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from reload
LWAPP image version 3.0.51.0
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: A4:93:4C:38:0B:67
Part Number : 73-12836-04
PCA Assembly Number : 800-33767-04
PCA Revision Number : A0
PCB Serial Number : FOC16192EK0
Top Assembly Part Number : 800-33775-03
Top Assembly Serial Number : FGL1620S4Y9
Top Revision Number : A0
Product/Model Number : AIR-LAP1142N-N-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar 1 00:00:07.701: *** CRASH_LOG = YES
Base Ethernet MAC address: A4:93:4C:38:0B:67
*Mar 1 00:00:07.903: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 1023 messages)
*Mar 1 00:00:09.952: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:09.973: %SYS-5-RESTART: System restarted --
*Mar 1 00:10:54.011: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar 1 00:10:54.978: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar 1 00:11:03.336: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 10.1.2.50, mask 255.255.255.0, hostname APa493.4c38.0b67
*Mar 1 00:11:13.516: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C3750-48P (9c4e.20d5.ea0c)
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (10.1.1.99)
Translating "CISCO-LWAPP-CONTROLLER"...domain server (10.1.1.99)
*Mar 1 00:11:23.962: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar 1 00:11:23.963: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar 1 00:11:23.965: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER
APa493.4c38.0b67>
Can you post the complete output to the vWLC command of "sh time"?
Console into the AP and reboot the AP.  Post the entire boot-up process.  We want to see what the AP is doing.
