2702i - association issue
We are having problems with 2702i AP when moved to a different port on a switch and connected to the same WLC. It takes approximately 15 minutes to associate with the same WLC
First it boots and AP gives the following logs:
*Mar 1 00:00:55.015: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.25.93.137, mask 255.255.252.0, hostname NAR-WAP2702I-SPARE1
*Mar 1 00:01:01.403: APAVC: Succeeded to activate all the STILE protocols.
*Mar 1 00:01:01.403: APAVC: Registering with CFT
*Mar 1 00:01:01.403: APAVC: CFT registration of delete callback succeeded
*Mar 1 00:01:01.403: APAVC: Reattaching Original Buffer pool for system use
*Mar 1 00:01:01.403: Pool-ReAtach: paks 42878 radio42270
*Mar 1 00:01:08.823: AP image integrity check PASSED
*Mar 1 00:01:09.231: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 1 00:01:10.155: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:01:10.163: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar 1 00:01:11.155: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar 1 00:01:11.395: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 1 00:01:12.395: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar 1 00:01:31.583: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 0 CLI Request Triggered
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (10.25.32.11) (10.101.18.17)
Not in Bound state.
*Mar 1 00:04:31.591: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
Not in Bound state.
*Mar 1 00:05:27.595: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
Not in Bound state.
*Mar 1 00:06:17.599: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
Writing out the event log to flash:/event.log ...
Once it reboots it gives the following logs :
*Mar 1 00:00:54.999: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.25.93.137, mask 255.255.252.0, hostname NAR-WAP2702I-SPARE1
*Mar 1 00:01:01.199: APAVC: Succeeded to activate all the STILE protocols.
*Mar 1 00:01:01.199: APAVC: Registering with CFT
*Mar 1 00:01:01.199: APAVC: CFT registration of delete callback succeeded
*Mar 1 00:01:01.199: APAVC: Reattaching Original Buffer pool for system use
*Mar 1 00:01:01.199: Pool-ReAtach: paks 42878 radio42270
*Mar 1 00:01:08.623: AP image integrity check PASSED
*Mar 1 00:01:08.807: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 1 00:01:09.903: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:01:09.911: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar 1 00:01:10.903: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar 1 00:01:11.139: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 1 00:01:12.139: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar 1 00:01:18.815: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 0 CLI Request Triggered
Translating "CISCO-CAPWAP-CONTROLLER.celanese.com"...domain server (10.25.32.11)
*Mar 1 00:01:28.819: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.200.17.44 obtained through DHCP
*Mar 1 00:01:38.823: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
This time it associates with the WLC.
The problem is that it takes 15 minutes for the whole process though it is joining the same WLC. We have around 200 APs that need to be relocated ..Please advise
Leo Laohoo
The AP is unable to contact the DHCP.  After the reboot, the DHCP starts dishing out Option 43.  So I'd be looking at this.
the first line of the output above, itself has the dhcp assignment and the packet capture has the DHCP option 43 as well which is configured accurately . i feel this has got to do with tagging
as per the following line:
ad requested by CAPWAP CLIENT. Reload Reason: Could not discover WLC using configured vlan tag 1000, Reload to failover to untagged.
No one can see this message because not all of the logs were posted.
