LAP dosen't broadcast SSID
saboodi
When I put my APs on Local mode the SSID disappear, and when return them to the Flex mode, they start broadcasting normally.
How I can but them on local mode and broadcasting?
2 Accepted Solutions
Sandeep Choudhary
are you using vWLC or other WLC to manage these LAPs ?
Dont forget to arte helpful posts
vWLC only support FlexConnect mode, hence once you conver to local mode, you cannot see SSID
https://www.cisco.com/c/en/us/products/collateral/wireless/virtual-wireless-controller/qa_c67-715130.html
Q.    Does the Cisco Virtual Wireless Controller support local mode?
A.     The only mode being supported in the Cisco Virtual Wireless Controller is FlexConnect local switching.
Rasika
**** Pls rate all useful responses ***
Sandeep Choudhary
I'm using vWLC!!
Rasika
