LAP1131 b/g radio not seen in WLC
mcaoile
The network consists of 133 RAPs/MAPs/1131 APs and all joined the WLC.  When I check the 802.11 a/n radio tab, I see only 129 APs and the 802.11 b/g/n tab I see 133 APs.  I found out that 4 LAP1131 is not showing in the 802.11 a/n tab.  I tried resetting the AP thru the WLC and still the don't see it in the 802.11 a/n tab.  I need help how to troubleshoot this problem.
Scott Fella
Radio could of gone bad. You can always console into the AP and then power cycle the AP. look at the output and see if you see an error for that radio or you don't see it as one of the radios when it is booting up.
-Scott
7 Replies 7
Scott Fella
-Scott
Hi Scott,
I'll try your suggestion tomorrow.  If there is an error or i don't see that radio, it means I have a faulty AP?  Since it is a LAP, I won't be able to enable that radio, am I right?
Yes that would mean its faulty.
-Scott
Hi Scott,
Can you please see the attached file below.  I think there is no radio in slot 1.
*Mar  1 00:00:10.280: %SNMP-5-COLDSTART: SNMP agent on host RSGT-AP25 is undergoing a cold start
*Mar  1 00:01:59.070: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:01:59.070: bsnInitRcbSlot: slot 1 has NO radio  <==================
*Mar  1 00:01:59.246: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:01:59.247: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:01:59.486: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:01:59.935: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar  1 00:02:00.250: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:02:07.371: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.1.3.179, mask 255.255.254.0, hostname RSGT-AP25
*Mar  1 00:02:17.906: %PARSER-4-BADCFG: Unexpected end of configuration file.
*Mar  1 00:02:17.906:  status of voice_diag_test from WLC is false
*Mar  1 00:02:17.980: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:02:20.292: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:02:20.328: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:02:21.292: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:02:21.293: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Mar  1 00:02:29.033: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.1.0.54 obtained through DHCP
*Mar  1 00:02:29.033: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.1.0.55 obtained through DHCP
Translating "CISCO-LWAPP-CONTROLLER"...domain server (255.255.255.255)
wmmAC status is FALSE
*Apr 23 19:06:25.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.0.54 peer_port: 5246
*Apr 23 19:06:25.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Apr 23 19:06:26.480: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.1.0.54 peer_port: 5246
*Apr 23 19:06:26.481: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.0.54
*Apr 23 19:06:26.481: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Apr 23 19:06:26.624: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Apr 23 19:06:26.732: %CAPWAP-5-CHANGED: CAPWAP changed state to UP
*Apr 23 19:06:26.783: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller CUSTOMS1
*Apr 23 19:06:26.828: %LWAPP-3-CLIENTEVENTLOG: SSID WLANdata added to the slot[0]
*Apr 23 19:06:26.831: %LWAPP-3-CLIENTEVENTLOG: SSID WLANvoice added to the slot[0]
*Apr 23 19:06:26.836: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Apr 23 19:06:26.842: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Apr 23 19:06:26.845: %WIDS-5-ENABLED: IDS Signature is loaded and enabled
*Apr 23 19:06:26.918: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
Leo Laohoo
Try rebooting the AP.  I see this all the time.
Abhishek Abhishek
As per your query i can suggest you that-
Please rebbot your AP and try once.If still it doesn't work then i can find that the radio must be faulty.
Make a note that
Data Rates Supported in CISCO LAP 1130 is-
• 802.11a: 6, 9, 12, 18, 24, 36, 48, and 54 Mbps
• 802.11g: 1, 2, 5.5, 6, 9, 11, 12, 18, 24, 36, 48, and 54 Mbps
Hope this will help.
Scott Fella
Yeah... Looks like the radio has gone bad and isn't detected. Need to RMA (if you have support) or replace it.
-Scott
