04-24-2013 03:18 AM - edited 07-03-2021 11:58 PM
New AP models 1600, 2600 and 3600 use one connector for both RF bands. I need the 2,4 band only. Is it possible to use old 2,4GHz wallmount patch antennas for those APs?
Solved! Go to Solution.
04-24-2013 04:41 AM
You can is that's only what you want to use. You would only have 2.4ghz from that ap. I would also make sure you disable the 5ghz and also assign one port as the primary tx and rx.
04-24-2013 05:04 AM
You need to disable the 5 GHz band on the AP.
Rating useful replies is more useful than saying "Thank you"
04-24-2013 04:41 AM
04-24-2013 05:04 AM
