Layer 2 SSID
MuhammadSaad_2
Level 2
Level 2
Dear All
I need urgent support on creating SSID as layer 2.
We have cisco WLC 2504 and 1602i access point. In our network we have in gate for guest.
I want to create one ssid and bind with vlan only. We can not creat interface on WLC b/c of static IP.
Kindly help its urgent...
Thank You
Leo Laohoo
You create a dynamic VLAN called Guest.  Give it a valid VLAN, IP address, subnet mask and default gateway.
Create an SSID called GUEST.  Bind that to the Guest Dynamic VLAN.
Your default gateway is the internet router's IP address.
See the device which gives the IP is the spoofing device so they can not give static IP.
I need only vlan bind with SSID and broadcast.
Muhammad,
The WLC needs a dynamic interface in order to communicate with any vlan/subnet. Without this, there is no communication between the WLC and that vlan/subnet.
-Scott
