layout question
Waleedmoos
Community Member
I would just like to know how or wot to do if i want a system in place as the wcs software. currenlty we are running the flex connect 7500 controller with fw
7.2.103.0 as i see on the compatibily matrix of the wcs it doesnt support this firmware. we are in process of procuring LMS will this be sufficient? I want the whole nine yards with wireless monitoring and wot not as wot wcs suppose to provide.
many thanx hope i was clear lols
Scott Fella
Well then you will want NCS. NCS (Prime Infrastructure) will eventually have LMS and NCS WAN rolled into it.
-Scott
