LDAP Web Authentication
cindyreyes
Community Member
1. In WLC GUI, Security > AAA > LDAP, what other User Base DN / User Attribute / User Object Type syntax to use when you have 2 or more OU (not pertaining to sub-OUs)? aside from using the domail alone, ex: dc=cisco,dc=com
2. Can OU be grouped in the active directory? then the WLC LDAP config will be pointing to the group created in the active directory?
Reference in configuring LDAP Web Authentication:
Web Authentication Using LDAP on Wireless LAN Controllers (WLCs) Configuration Example, Document ID: 108008
Any help would be appreciated. Thank you in advance!
0 Replies 0
