LEAP / ACS User Exceed Max Session problem
f-vanryckeghem
Level 2
Level 2
Hi all,
I have installed AP 1200 with ACS ans LEAP. I configure a user with only 1 login allowed.
I could not connect anymore to the network and I am sure that no one is using this account ( it's a lab).
The reason of the authentication failed in the ACS is the following : User exceeded max sessions
I set the user to Unlimited session ... and everything was OK.
ANy idea about the problem ?
FRederic
sbilgi
Level 11
Level 11
I think you are hitting on the bug CSCea08638
Thanks for the info ... but I could not find the bug your mention with the Cisco Bugtoolkit ...
Could you send me the bug description ?
regards
Frederic
