LEAP and MAC authentication thru ACS 3.2 for AP1100
boonteongng
I want to configure wireless user to be authenticated thru MAC and LEAP at a ACS server. Windows user database is used and MAC address are configured as user in the ACS User list.
In the AP ( web configuration ) SSID manager, should I choose Open Authentication with MAC and EAP or Network EAP with MAC authentication ?
I tried Network EAP with MAC authentiocation but it doesn't work.
I tried Open auth with MAC and EAP + Network EAP with no option, the authtication will go thru with or without the MAc address in the ACS.
Any thought ?
a-vazquez
Level 6
Level 6
If the client has both MAC and EAP Authentication, you can allow the client to log on to the network with only MAC Authentication. If you don?t want the client to log on to the network if the MAC Authentication succeeds and then go to the EAP process, that can also be configured. To set up EAP, you must select Require EAP under Open authentication on the AP Radio Data Encryption page to force client devices to perform EAP authentication if they fail MAC authentication. If you do not select Require EAP, client devices that fail MAC authentication might be able to join the network without performing EAP authentication. For more information, please see the following url,
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/accsspts/ap350scg/ap350ch4.htm#828
55 . Please see step 4 and step 5. Also, you might like to see the following url which has a Summary of Settings for Authentication Types,
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/accsspts/ap350scg/ap350ch4.htm#xtocid24
The AP I used is AP1100. I just select Network EAP with Mac authentication. It authenticates both EAP and MAC. The MAC address has to be small letter at the ACS user database.
If Open auth with EAP and MAC are selected, I found that only EAP is verified from the debug command. That is why any MAC address can pass thru.
slupetti
OK if i use MAC and Peap for the same PC adapter
authentication fail.But if Peap PC adapter it's not in MAC ACS DB the authentication work fine
