LED on AP
saquib.tandel
Level 7
Level 7
LED on the Wireless AP displays different colors ( RED / Blue / Orange / Green )  ; can someone care to reply what each color indicates.
thanks
ST
Scott Fella
You will see the AP go through the various colors when the AP is powered up.  Solid Green means it is up but no associations.  Blue means there is at least one device associated to that AP.  Red is bad if that says on and Orange, I don't know.
As the access point attempts to connect to the controller, the LEDs cycle through a green, red, and amber sequence, which can take up to 5 minutes
http://www.cisco.com/en/US/docs/wireless/access_point/1140/quick/guide/ap1140gsg.html#wp37791
-Scott
Orange is typical of a power issue // typically POE.
