Lightweight AP to Autonomous conversion without Controller
ciscokid7181
Level 2
Level 2
Dear Folks,
I do have 1131 LWAPP in home, i was wondering if i can convert to Autonomous . I read in the documentation, that only way is to use with controller. Is it true ? or can i convert without connecting to WLC .
SID
ajuarez
Level 3
Level 3
1) Go to your Computer and from the tool menu -> folder options ->uncheck the hide extensions for known file types option.
2) Download the IOS image ( you can get this ios image from cisco.com) on your desktop.
3) Rename the image into c1130-k9w7-tar.default
4) Give your computer Ethernet an address in the range 10.0.0.2 till
10.0.0.30
5) Run the tftp server on your computer.
    - Make sure that the directory of your tftp server is the desktop.
    - Specify the AP address on the tftp server if needed.
6) Connect the AP to the computer with Ethernet cable.
7) Remove the power from the AP.
😎 Press and hold Mode button on the AP, and insert the power jacket in the AP.
9) Keep pressing on the Mode button for (20-30 seconds) until you see RED Led.
10) Wait until the image installed and all led lights return to green
ajuarez
Level 3
Level 3
10.0.0.30
