Limiting 1 device per user name on WLC 3500 Series using Radius
GiovanniN1991
Good morning,
I have a 3500 series WLC with 8.5.131.0 version software connected to a FreeRadius server (with Daloradius GUI).
I would like to know if is it possible to manage the number of devices connected on a specific SSID, limiting each username to one only device.
I'm not capable of handling simultaneous logins number via radius server, so, since I can see the username used to connect in the Clients tab of WLC, I was wondering if I have the chance to use this information to limit logins to 1 device only per user name.
Thank you in advance.
G
2 Accepted Solutions
Leo Laohoo
  1. Security > AAA > Disabled Clients > User Login Policies.
  2. Change the "0" (default) to "1".
For those that end up with this same issue:
Set User Login Policies to 1 as @Leo Laohoo  said, then go to Security>Advanced EAP to disable max-login-ignore-identity-response.
Devices that were logged in BEFORE the policy was enforced will not be kicked out and are not counted toward reaching the max-1-login-per-user limit, so you still have one empty slot to log another device.
Be sure to test these settings using at least 2 different devices to be sure that everything is working as expected.
Leo Laohoo
Hi Leo,
thank you for answering. I've already found this tip in the forum, but it didn't work. I must also say that the user we used for test purpose had already 2 devices logged in (which didn't get disconnected), and was also able to add a third one.
The culprit may be related to this: "1. When using 802.1X security make sure max-login-ignore-identity-response is disabled"
I can't find this setting in the GUI.
Can you help me with that?
Do I have to do something in paritcular after limiting Login to 1 to test it out?
