Limiting Data Rates for certain APs in WLC
recep.sefer
I have 55xx WLC
I have 100 AP
I want to limit higher "DATA RATES" for certain APs, how?
I see it is possible to do it for all a/n or b/g/n radios
Please Help
Leo Laohoo
Convert the APs into autonomous.
Stephen Rodriguez
in the current versions of the WLC, the rates that are used are defined controller wide and not on a per AP basis.
If you have multiple WLC, you could assign the AP that you want to have the higher rates to a different WLC than the others.
If you don't, then as Leo said, you'd need to go back to an IOS solution.
If I may ask, what is the need to have only some AP to have the higher rates?
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
