Linksys wireless router WCG 200
catchrcisco
I am trying to install a Linksys WCG200 wireless router in my SOHO office with five employees. How do I configure it so that people in the neighboring office don't get access to any data moving on this network? Thanks in advance for any help that someone can provide.
Cheers!
drolemc
Level 6
Level 6
Since this is a wireless network you are planning to deploy, you will have to encrypt the data using strong encryption mechanisms in order to avoid eavesdroppers from being able to interpret the data. If you have radius server at your end, you can use WPA2 which uses 802.1x authentication with AES encryption.
Thank you!
