Showing results forĀ
Search instead forĀ
Did you mean:Ā
LINKSYS
yuanguitao
Community Member
Hi  Guys,
I met a problem which attached to LINKSYS(WRT54GC ver. 2.0). Well, i used a wireless router outsiede, but i can't get the signal in my bedroom, since the cable in my house is not long enough to reach my bedroom. so i wanna use another wireless router as a AP to relay the signal outside. but when i access to the web management interface, i can't find that work mode. so pls help me to solve this problem. Thank you.
kaaftab
Level 9
Level 9
Try configuring the other AP as access bridge mode and you can easly extend you signals
