lisence smart and RTU on cisco controller 5520
akram.root
Level 4
Level 4
Hello all,
I am beginner in the wireless world , and i want your help .
I have a cisco controller 5520 appliance , and i have two type of lisences  smart licensing and RTU
Question  1:
the RTU license that is mean 5520 AP Adder Licenses ?
Question 2:
Can i use both lisence ( RTU + smart licence ) together in the same controller without any problem ?
Thanks in advance
Best regards
Sandeep Choudhary
1. the RTU license that is mean 5520 AP Adder Licenses ?
Its not same. Cisco is going a new way to license the access points on WLCs. You now buy Cisco “Right to Use” (RTU) Licenses and just configure the AP license count at “Management / Software Activation / Licenses”.
How to do it: https://networkguy.de/cisco-right-to-use-rtu-licensing/
2. Can i use both lisence ( RTU + smart licence ) together in the same controller without any problem ?
Best case would be to migrate from RTU to Smart licensing.
https://www.cisco.com/c/en/us/td/docs/wireless/technology/mesh/8-2/b_Smart_Licensing_Deployment_Guide.html
Dont forget to rate helpful posts
