Load Balancing between AP's
n.somaiya
Community Member
How does Load balancing in AP works.My requirement is that if the no. of client in any of the AP's exceeds 10 users other users should automatically shift to another AP.Is their any configuration changes required to do this?
MICHAEL YOUNG
Community Member
If the AP's are relatively close you can specify the max users on a particular SSID on the AP.
Example:
Radio A:
int dot0
ssid test
max-associations 10
Radio B:
int dot0
ssid test
max-associations 10
Hope this helps....
