Load threshold violation 802.11 a/n
John Garrett
I keep getting these minor alarms "Load threshold violation 802.11.a/n".  Where are these thresholds defined?  I have Prime 2.1 and 5508 controllers 7.6
rsaeks
John,
You can change the alert threshold for each band via Wireless > 802.11(a/n/ac) or 802.11(b/g/n) > RRM > General.  You will see Profile Threshold For Traps and there you can increase or decrease the number of clients associated to a radio that will trigger the alarm.
You can also do this through the CLI with:
config rf-profile client-trap-threshold NUMBER
Hope that helps!
Randy
Perfect Thanks!
Stephen Rodriguez
On the WLC you can adjust the load threshold in Wireless > Network > RRM > General
You want to adjust the Load Threshold for Traps
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0/configuration/guide/c70/c70rrm.html#wp1176921
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
