Loadbalacing Issue with BR350
We are using 2 BR350 with Omni antenna, they are about 2m space between the 2 antennas of the 2 Br350.
They have different channels but the same signalstrengh
from to the clients
there are about 40 Clients (WGB350 - with leap) around the bridges but they dont loadbalance them (20:20) they are only connected to ONE BR350. you can bind the wgb to on bridge then it works but they dont loadbalance right!?!?!? the aironet extentions are on.
sw on the br350 are 12.04. i know that this is not the latest!. does anybody has similar issues? or is ist maybe a hardware problem?
regards Bernhard
pradeepde
Level 11
Level 11
I am not sure whether these products support Loadbalancing, is the other AP working? Try shutting the one to which all devices are connecting to and check if the other device detects them.
