Local management users and Radiusproblem
johannf
Community Member
I have created a wlan for guests and would like to only authenticate guestusers against Local Net Users database on the WLC.
My problem is that it is also possible to log on with usercredentials for radiusauthentication.
I have not enabled any AAAservers for the guestwlan.
Any tips how to stop the radiusauthentication for this wlan ?
JF
Stephen Rodriguez
You can also, uncheck the Network User box under the Radius Configuration. This check box allows the WLC to use the AAA server globally for any WLAN. Just need to make sure that under your secure WLAN, you list the AAA server explicitly, which is a best practice.
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Scott Fella
That is how it currently works, but here are two options:
You can either change the Web Radius Authentication to CHAP or MD5-CHAP which is located in the GUI... Controller | General
Or else you can create 3 fake radius servers on the wlc and then specify those three under the guest wlan radius servers.
-Scott
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
OK, thanks. This worked fine.
JF
